launching MP in a particular disposition
lian
Post by lian »
Is there a way to launch MP with a particular disposition ?
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: launching MP in a particular disposition
you means layout?
lian
Post by lian »
En français "disposition", I suppose layout in english :-)
currently no, but i'll add an option to use a layout...
lian
Post by lian »
Great. I just discovered the very importance in layouts for XnViewMP. As I got two monitors, I would be able to launch the program directly in the monitor I want with good size. And it could be very convenient to move the program from one monitor to other with automatic size changing.
dietmar
Post by dietmar »
Pierre,
maybe I just haven't found the correct way to use layouts, but I can save layouts A to E and I can restore those. But which is the layout MP uses at startup? On Ubuntu it always defaults to some layout fairly unusable on my screen with very narrow frames at the left and botton areas.
I'd like to have MP either default to the last layout used or always default to layout A if defined.
Regards
Dietmar
lian
Post by lian »
dietmar wrote:Pierre,
Regards
Dietmar
For me - Windows - it keeps in memory last layout used.
lian wrote: For me - Windows - it keeps in memory last layout used.
yes it's that
dietmar
Post by dietmar »
yes it's that
Yes, it does now. Didn't in 0.61. Sorry.
Dietmar
See Issue 247 for current status and details.
