Is there a way to change default zoom?
AndrewKun
How can I set default zoom to 100% in the viewer? Right now the default is fit to window size. I could do that in XnView classic, but in XnViewMP I looked all over the settings and can't find that option.
Re: Is there a way to change default zoom?
when you open a tab view?
AndrewKun
When I open a new picture (i.e. from file browser of from XnViewMP browser). Sorry I wasn't clear the first time.xnview wrote:when you open a tab view?
oops66
Hello, You can "lock zoom" at 100% first ...AndrewKun wrote:...When I open a new picture (i.e. from file browser of from XnViewMP browser)
AndrewKun
How do I do that? I can press the hotkey (default *) to change zoom to 100%, but I need that zoom level to be default for all the pictures I open. How do I do that?oops66 wrote:Hello, You can "lock zoom" at 100% first ...AndrewKun wrote:...When I open a new picture (i.e. from file browser of from XnViewMP browser)
oops66
... Within the contextual menu (right mouse clic) into the View mode (or full screen mode) ?
AndrewKun
Thanks, I've done it using "Lock zoom" function in the context menu, which I didn't know existed there. I think this also shold be configurable in the "View" settings. Anyway, case solved, thanks for the helpoops66 wrote:... Within the contextual menu (right mouse clic) into the View mode (or full screen mode) ?
oops66
+1 (for view mode, and fullscreen mode);-)AndrewKun wrote:... I think this also should be configurable in the "View" settings...
CreativeWorld
This kind of works. Yes I lock it a 100%. For pictures smaller than the window this works perfectly, however for big high resolution pictures how can I make it be fit to screen (100% on high resolution picture) means you're really zoomed in.oops66 wrote:Hello, You can "lock zoom" at 100% first ...AndrewKun wrote:...When I open a new picture (i.e. from file browser of from XnViewMP browser)
So to recap:
picture < less than screen: make it 100%
picture > more than screen: make it fit to screen
How can I accomplish the above? Thanks.
I third this! Don't know why a viewer that taunts itself as the most advanced doesn't have this simple option!oops66 wrote:+1 (for view mode, and fullscreen mode);-)AndrewKun wrote:... I think this also should be configurable in the "View" settings...
quapurna
Are this discussion and the following one related?
http://newsgroup.xnview.com/viewtopic.php?f=60&t=28327
Thanks.
Thanks.
CreativeWorld wrote:
So to recap:
