Hi, new user here moving from Picasa. Very pleased with XnView so far but having some category related issues.
"Import XMP subject or IPTC keyword to DB Categories" and "Export DB Category to XMP subject and IPTC keyword" are turned on from settings.
1) I would like to display the category info below thumbnails but so far managed to only show IPTC keywords. Is it possible to also show XMP subject?
2) When removing a file from its folder via Windows explorer, the count number next to categories doesn't update. Is there no automatic tracking?
3) Is it possible to remove "Rating" and "Colour Label" from Categories panel?
Show XMP metadata in thumbnail subject and other questions
orchid
Re: Show XMP metadata in thumbnail subject and other questio
Not yetorchid wrote: 1) I would like to display the category info below thumbnails but so far managed to only show IPTC keywords. Is it possible to also show XMP subject?
If you remove file outside XnViewMP, XnViewMP must running to detect changes2) When removing a file from its folder via Windows explorer, the count number next to categories doesn't update. Is there no automatic tracking?
No, but i'll add a setting3) Is it possible to remove "Rating" and "Colour Label" from Categories panel?
