How to Editor context menu?
mrwul
Post by mrwul »
Is it possible to adjust to the context menu of XnViewMP editor.
e.g. after selecting a section I would like to have "Copy" as a context menu item
(now under edit>copy)
oops66
Re: How to Editor context menu?
Post by oops66 »
+1 good idea/suggestion ;-)
you means to have a different menu if there is a selection?
mrwul
Post by mrwul »
Not only when something is selected.
e.g. open a file
now you want to copy contents (all) to clipboard.
Edit>Select All
Edit>Copy all (or CTRL-C)
My suggestion is to add more (all?) the editing features to the context menu.
For stepping to the next page I can use either <= or => in the toolbar or pageup/pgdn key.
But it would be nice if there were more 'Edit' features under the context menu as well.
In full screen-mode, 27", rmb is faster than the edit button in the toolbar :wink:
the problem is that some users want 'file next/previous', and others like you want copy/paste :)
mrwul
Post by mrwul »
then that is bad luck. thought it would make more sense to have the 1-key 'manouvre'-buttons (pgdn, pgup, home, end) remove from the context menu and make place for editing features (such as Undo/Redo, etc)
Anyway, no problem.
oops66
Post by oops66 »
... Ah ...My idea was only to allow the ability to the user to customize/choose the items visible/hidden into the context menu (by cheking/unchecking an options from a list of items) ... ;-)
