How to edit EXIF info in batch, simply?
Farrukh
Post by Farrukh »
First of all, my compliments on developing such an awesome tool. I'm a user of Faststone image viewer, and I've found XnView MP as another master piece. :) . Thanks a bunch for such a nice software facility.
So, I'm looking for the feature, Editing Exif in batch. I tried using IPTC/IIM/XMP metadata for number of jpg and png files in batch, but that doesn't update EXIF info (File Properties --> Details).
I've found ExifTool.exe in Addons folder, but not sure from where it can be used to edit EXIF in batch. Except, I only see non-editable info viewer by Exif tool from where I can only copy information.
I'm using:
XnViewMP
Version 0.64 (Jan 4 2014)
Libformat version 6.53
using Windows 8, x64 bit
best regards
Re: How to edit EXIF info in batch, simply?
currently no way to edit EXIF metadata
Farrukh
Post by Farrukh »
I think, ExifTool.exe can edit Exif info. So I will have to use it our of XnView box... :x
