Status bar information
Apxu
Post by Apxu »
Now (version 0.64) browser mode status bar show number of objects in current folder (without total size) and number and size of selected objects.
I miss total size of all objects in folder.
Option in "Settings" for status bar info selection will be even more convenient. (As made for file thumbnail labels or browser tooltips, for example).
Re: Status bar information
Apxu wrote: I miss total size of all objects in folder.
When there is no selection?
m.Th.
Post by m.Th. »
Apxu wrote:Now (version 0.64) browser mode status bar show number of objects in current folder (without total size) and number and size of selected objects.
You mean this one?
If you have no selected files it shows this info.
m. Th.
Apxu
Post by Apxu »
m.Th.
Program do not show total size of files in current folder at all (excluding one case).
I use "XNview MP" filelist in details mode (without thumbnails).
1) Image
No objects selected. Cursor is placed to ".." entry (up level directory).
2) Image
Some objects selected. From one to all, six in this case.
3) Image
No objects selected after "Move to" command execution. This is single case, when "XNview MP" shows total files size information.
But program behavior in this case is incorrect (or at least inconvenient) because Preview pane don't show file under cursor in filelist after this operation. (See my " 'Move to' in browser" post.
Actually, all I want is this "88 object(s) [23.16 MiB]" string will be shown always, have I selected files or not.
P.S.: sorry for delay and thanks for great program!
