skipping existing files takes to long when batch converting
rsf
Post by rsf »
Hello.
Skipping existing files takes just a little to long when batch converting.
I think they're being loaded and only after xnview check is a file already exists.
When converting hundreds of big files it can take a while.
Re: skipping existing files takes to long when batch convert
yes right, file is loaded first...
