Replace one color with another?
Peter2
Post by Peter2 »
I don't know if it's a really simple or a really weird question: How to replace one color with another in a simple and quick way (with XnView or MS Paint)?
Example:
Change the grey areas (also inside the blue text) to yellow!
Peter
Re: Replace one color with another?
you can use batch convert with 'replace color'
Peter2
Post by Peter2 »
xnview wrote:you can use batch convert with 'replace color'
Thanks. But this feature does not exist in XnView, right?
Peter
Tools > Batch Processing...
Peter2
Post by Peter2 »
Thanks.
Peter
