jpegtrans options cancels processing
andekande
Post by andekande »
If you use -jpegtrans exif and some more options like -resize longest or -rmeta then the file gets copied to output in original format - no processing taking place. Console outputs:
Lossless transformation of N:\P1020434.JPG : NOT NEEDED
I consider this a bug.
In another post I read that rotation does not change exif header accordingly. Is this fixed yet?
By the way, I am using v6.50
Re: jpegtrans options cancels processing
andekande wrote:If you use -jpegtrans exif and some more options like -resize longest or -rmeta then the file gets copied to output in original format - no processing taking place. Console outputs:
yes it's a known issue. But here what is the solution?
* apply lossless transformation
* load jpeg and apply other process?
I think that it's fixed now
