hi there
i use xnviewmp 0.64 unter windows 8.1x64
when i do this
https://www.dropbox.com/s/7l7xtektgxwx5 ... .54.36.png - and you see my image on the right preview pane
i get this :
https://www.dropbox.com/s/yd6ebvmhltc8d ... 3-89_1.bmp
and i really can't understand why. If i go from the batch convert or export menu, it works ok, no problems there with standard settings.
Why the right click menu, "convert to jpeg" produces this? and leaves the .bmp extension? is there any way for me to fix it?
Error when converting to jpeg from right click menu
kavadias
Re: Error when converting to jpeg from right click menu
For JPEG, please check quality in Format settings. About bmp, it's a bug
Bug confirmed and will be fixed. See issue Issue 270 for current status and details.
