Powerful Multi-Page File support
m.Th.
Post by m.Th. »
There is a feature in XnView Classic which allows users to generate multi-page files (see Create | Multi-Page File) which isn't yet implemented in XnView MP.
However this feature can be much easier implemented than one thinks. ;)
...and also in a much more powerful way! :)
Just add a single checkbox.
See here:
When the highlighted checkbox will be checked and a compatible output format is chosen, the Batch Convert will generate just one output file having as pages the processed input images.
m. Th.
Re: Powerful Multi-Page File support
As a useful addition to the Batch convert... Output tab -->Yes please, +1
As an implementation of XnView Classic's Create > Multi-Page file... -->Not sure, that would mean performing a batch convert with no Actions, which isn't entirely intuitive...
m.Th.
Post by m.Th. »
cday wrote:As a useful addition to the Batch convert... Output tab -->Yes please, +1
Exactly this is my proposal: To implement the same functionality from XnView Classic in a better way "as a useful addition to the Batch convert..." :)
m. Th.
m.Th.
Post by m.Th. »
...and it will be available also in XnConvert... :)
m. Th.
