Browse multi folders in multi tab ?
navmesh
Post by navmesh »
Hi, thanks for the XnviewMP ,It really makes my day
May i ask for a feature, sothat we can browse with multi tabs (instead of multi windows) As far as i know XnviewMP can only view (not browse) in multi tab , but i want to browse different folders in different tabs (each tab is one folder)
Thanks again ^^
oops66
Re: Browse multi folders in multi tab ?
Post by oops66 »
Hello ... +1 ... An old request ;-)
m.Th.
Post by m.Th. »
It is something little different than http://newsgroup.xnview.com/viewtopic.p ... 97#p113203
He requests two different tabs with browser panes. Well, while it provides some added value, I think that this isn't so useful compared with having two browsers in the same tab. Even if the two browsers are asymmetric (IOW the 2nd one to just a thumbs pane with reduced functionality compared with the main one).
...But, guess what, I succeeded once to have two browser tabs. IIRC it was a crash at some upgrade and I had two browser tabs. However it didn't last long... :(
m. Th.
