Editing the tagged list by text ?
hepa
Post by hepa »
Hello everybody,
i want to ask for some features :
1.
Edit list rated/tagged files ,by this we can view the file list ( it ' s in text format and we can copy all ,and edit by any text editor)
such as
c:\images\images1.jpg || 4 (|| is the separator and 4 is the rating )
e:\others\scenes2.png || 3
2. i will be happy if we can add more tag/rating fields ,which we can define
Thanks ^^
m.Th.
Re: Editing the tagged list by text ?
Post by m.Th. »
1. "||" ?? ...perhaps is better to have as separator the Tab character? It is the standard in such situations.
Ok, you want to edit it with the text editor. How? To change the rating? But in a text editor you will not see the image? And after that?
What do you want to achieve?
2. You have already Categories which you can assign in an unlimited number to any photo.
Again, what do you want to do?
m. Th.
oops66
Post by oops66 »
...Editing the tagged list by text ?
.. Have you tried, for example for a listing for the tagged pics (or others categories, ratings, colour label, etc...) ... then "category tab"\special items\tag ... select all ... create\ file listing (format .txt)
{Directory}{Filename With Ext}
