I've downloaded the latest version of the program, but I can't open a DJVU file with it.
The list of file formats contains this format. Please, fix it.
Win7 x64 Professional (fully-updated)
I tried to use 64-bit version of XnView MP.
Can't open a DJVU file
Re: Can't open a DJVU file
XnViewMP can only load old format of DjVu...
xtemp09
Please, asterisk the DJVU entry in the list of file formats.
I think the position is that XnView Classic 'Full' includes a DJVU plug-in XMrSid.dll which supports an early DJVU standard which was limited to single pages, and that there is likely no open source plug-in available for the later DJVU 3.0 standard.xtemp09 wrote:I've downloaded the latest version of the program, but I can't open a DJVU file with it.
I don't see a plug-in installed in my XnViewMP installation although there may possibly be one there somewhere, but in any case XnViewMP x64 would require a 64-bit version.
If it's any help, Irfanview includes a proprietary plug-in which opens multi-page DJVU files, but there's no support for saving to DJVU format. There are also various freeware Windows DJVU viewers available, if that is all you need.
Currently i can't use new DjVu library (license limitation)
