Import and Sort Problem
tonyt
Post by tonyt »
Hi
If I use import and sort, it works fine except:
If I assign a category that already exists as a sub category - a new category is created. Clear as mud?
I have a Category setup as -
Category=Location
Subcategory=Cornwall
If I assign a category of Cornwall to the import it creates a new main category of Cornwall, how do I assign a sub category to the import so that a new category is NOT created. Hope that makes things a bit clearer and someone can help me.
Cheers
tonyt :D
m.Th.
Re: Import and Sort Problem
Post by m.Th. »
Perhaps is a bug. I don't know.
Are you sure that you type exactly the keyword? Perhaps the search to match with the existing keyword in tree is case sensitive?
Anyway, the Import dialog is a new feature (appeared in 0.64) and from GUI design it seems that it has a potential but it needs improvement. I would choose another way to enter the categories/keywords - more safer and powerful.
In fact I would have just a single, central engine to select them. But let's wait for 0.65.
Another improvement for Import dialog would be the possibility to enter a custom destination (sub)folder, not only yyyy/mm variants.
Another one is to allow Move not only Copy files.
Another one is a custom rename mask.
m. Th.
schultzter
Post by schultzter »
m.Th. wrote: Another improvement for Import dialog would be the possibility to enter a custom destination (sub)folder, not only yyyy/mm variants.
I agree. I organize the physical files by yyyy/yyyy-mm-dd so it would be nice to have that as an option or be able to enter that format manually. Thanks,
Version 0.72 x64 (Dec 19 2014) on Arch Linux
Headed for the second star to the right and straight on 'til morning...
m.Th.
Post by m.Th. »
Yes- in fact, the most common layout among photographers is by far {insert your temporal organization here: yyyy/mm, yyyy/yyyy-mm-dd aso.} and in this temporal organization to have subfolders with the name of the event:
  07
  08
     Wedding - Jane Doe, John Doe
     Portrait session - John Doe Jr.
     Sports - Car Racing
etc....
m. Th.
it's not a problem of "import and sort" but importing XMP keywords
"Cornwall" is added to the files but without hierarchical keyword, so must i add this file to a root "Cornwall" category or find the first "Cornwall" category?
m.Th.
Post by m.Th. »
xnview wrote:it's not a problem of "import and sort" but importing XMP keywords
Find first "Cornwall" category.
Usually the users import images in stages / batches and expect to have the images merged in their category tree.
m. Th.
See Issue 486 for current status and details.
