Change sort order from viewer?
insanemachine
Post by insanemachine »
Hello.
Is it not possible to change the sort order from the viewer? I can't seem to find anything under the menus ("View" or others).
I use xnView as a viewer only, by browsing images through windows explorer, double clicking them and going through them one by one in the XnViewer, and thus I'm looking for a convenient way to change the sort order without having to open XnBrowser. I usually have it sort by date but when I want to browse a comic or a magazine, I need to quickly swap to alphabetical sort to get the pages in the right order.
Re: Change sort order from viewer?
Viewer use the same sort settings as the browser
insanemachine
Hi, thanks for the reply.
Yes, I'm aware of that. I was wondering if there is any way to change those sort settings from within the viewer - without going through the browser.
Under the "View" menu of the browser, you can change sort settings. Under the "View" menu of the viewer however, these options are missing :(
currently you can't
