in the previous version fo XnView there was the cropping functin in the context menu. Also the tool to edit a picture to e. g. put some painting or text on it is not available. Now I miss this functions in XnView MP. Is it possible to get this functions also to MP?
Regards,
lutfi9
Functions in context menu and painting tool
Re: Functions in context menu and painting tool
you means 'Crop' in context menu?
And painting tools will be added in a future version...
lutfi9
Yes, I mean "Crop" function. Now it is under "Edit" in the Menu. How can I put it into the context menu like the previous XnView version?
i'll add itlutfi9 wrote:Yes, I mean "Crop" function. Now it is under "Edit" in the Menu. How can I put it into the context menu like the previous XnView version?
lutfi9
That would be perfect, thanks.
I think it would be nice if there is also a possibility to customize the context menu on our own. Maybe this helps also other users, too.
