Delete, Cut, Clear Problem
TerryNeely
Post by TerryNeely »
When I select a portion of the image by drawing a box around it and try to delete it with the Del key, cut or clear, the entire box turns Black instead of white. How can I delete an area and have it be white?
Re: Delete, Cut, Clear Problen
TerryNeely wrote:When I select a portion of the image by drawing a box around it and try to delete it with the Del key, cut or clear, the entire box turnes Black instead of white. How can I delete an area and have it be white?
I'll add a color selection to choose the color
