[Fixed]Lossless jpg keys stop working.
Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
Fixed. v.1.82 Please put other problems, if any, in new topic.
Re: Lossless jpg keys stop working.
Strange, perhaps the same problem like Dialog & toolbar item??? I can't reproduce it...marsh wrote:Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
It works fine here, in view and fullscreen mode.tengler wrote:It is not possible to rotate pictures (Ctrl+Shift+L and Ctrl+Shift+R) in view and fullscreen mode.
It doesn't work only in special "lite" fullscreen mode (when you press F11 in Browser mode).
These shortcuts work in view and fullscreen mode:
Rotate -90 ... Shift+L
Rotate 90 ... Shift+R
Rotate -90 lossless (jpeg) ... Ctrl+Shift+L
Rotate 90 lossless (jpeg) ... Ctrl+Shift+R
Lossless rotate shortcuts work also in Browser, so I wonder why they don't work in Fullscreen "Lite".
I'll check it later...marsh wrote:Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
ganderpe
I've got the same Problem: It worked once, and after I disabled the Dialog "...changes your picture", Ctrl-Shft-L or R didnt work anymore.marsh wrote:Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
I tried the Professional Version: it has the same Problem
OK, confirmed, aganderpe wrote:I've got the same Problem: It worked once, and after I disabled the Dialog "...changes your picture", Ctrl-Shft-L or R didnt work anymore.marsh wrote:Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
I can't reproduce itDreamer wrote:OK, confirmed, aganderpe wrote:I've got the same Problem: It worked once, and after I disabled the Dialog "...changes your picture", Ctrl-Shft-L or R didnt work anymore.marsh wrote:Lossless jpg keyboard shortcuts stop working in browser and viewer if 'do not show again dialogue' is checked. I'm using an xnview.ini created with v.1.80.1.
Try this:xnview wrote:I can't reproduce it
- default options
- go to viewer
- press ctrl+shift+R (or L)
- mark "do not show this mes. again"
- OK
- press ctrl+shift+R (or L) again
= it doesn't work
