Wrong caption "Attach/Detach preview panel"
herb
Post by herb »
I work with XnViewMp 0.64 on Windows.
When I right click in an empty area of the toolbar a context menu appears with a menu entry
- attach preview panel: in case of the preview area is displayed
- detach preview panel: in case of the preview area is not visible
As far as I understand should both captions "attach ..." and "detach..." be exchanged.
Best regards
Herb
Re: Wrong caption "Attach/Detach preview panel"
Attach preview panel is to put preview in the tabs, and dettach as a dock panel
herb
Post by herb »
thanks Pierre for your info.
You are right, I did a mistake. Sorry for the confusion.
Best regards
Herb
