0.64 Linux: Zoom Quality of SVG images
yossic00
Post by yossic00 »
When zooming in svg images the quality is not as good as using gnome's image viewer (high quality zoom is enabled in XnView for both zoom-in and zoom-out):
Is there anyway to improve it?
Thanks,
Yossi
oops66
Re: 0.64 Linux: Zoom Quality of SVG images
Post by oops66 »
Hello, ... right I also have this problem (xnviewMP0.64 vs eog - too)
Tested with this svg file: ;-)
m.Th.
Post by m.Th. »
It seems that the program rasterizes the vectorial data first time when it shows on the screen. The zooming engine needs to be reworked specially for vectors in order to take at each different zoom level the data not from the rasterized bitmap but from the original vector.
...but nice tiger tough. :)
m. Th.
yes currently SVG is imported as bitmap
