multiple convert
Tekila
multiple convert
Post by Tekila »
I would like to make a script that convert a folder with many photos and copy them to an FTP with the same folder structure.
Example :
I have the directory "c:\photos\"
In this directory, I have many directories like "2014-01-01", "2014-01-15", "2014-02-08", ...
I want to take all these directories and the photos and :
- resize them in 1024x768
- copy the resized photos to ftp://.../2014/
- In this directory, I would like to have the same structure : ".../2014/2014-01-01", ".../2014/2014-01-15", ...
I use the "convert" option from XnView MP and I am actually able to resize the photos and copy them to the FTP, but I am not able to recreate the same folder structure as the original photos.
Can anyone help me ?
Sorry for my English (I am French ;-) ),
Sebastien
Re: multiple convert
Tekila wrote:I use the "convert" option from XnView MP and I am actually able to resize the photos and copy them to the FTP, but I am not able to recreate the same folder structure as the original photos.
Hello, are you selecting 'Keep folder structure' ?
That's 'Conserver la structure des dossiers' in the French version, as I'm sure you know. :wink:
Tekila
Post by Tekila »
Thank you for your answer.
I tried your solution but it does not work.
In the result folder, the photos aren't stored in subfolders : they are all in the main directory.
In my example, I take all the photos from the directory "h:\photos\" : in this directory, I have different directories : "2014-01-01" ...
The result is that after the "convert script", all the photos are in the directory "h:\bureau\test" but there are no subfolder.
Tekila wrote: ... I take all the photos from the directory "h:\photos\" : in this directory, I have different directories : "2014-01-01" ...
The result is that after the "convert script", all the photos are in the directory "h:\bureau\test" but there are no subfolder...
A bug, I think:
On the Input tab, 'Add folder...' adds the images in the selected folder and any sub-folders, but not the folder structure...
oops66
Post by oops66 »
Hello ...And if into "nom de fichier" you put: "/{Folder name}/resultat_{Filename}" (for linux) ?
... or maybe in windows: \{Folder name}\resultat_{Filename} ?
Or for full directory (linux): "{Directory}/{Filename}" or wondows ? "{Directory}\{Filename}" ?
oops66 wrote:Hello ...And if into "nom de fichier" you put: "/{Folder name}/resultat_{Filename}" (for linux) ?
In comparison with XnView Classic, the problem seems to be at the input rather than the output tab: images within the selected folder structure are loaded to the Input tab without their associated paths...
oops66
Post by oops66 »
Here under linux that works, so far ... ;-) ... but I don't know with the windows version ...
for full directory in name file (linux): "{Directory}{Filename}"
for full directory structure (linux): "{Directory}/{Filename}"
or with the the last dir (linux): "/4-emails_{Folder name}/{Filename}" ... I use this one (for "filename") with no path in "folder" (= current dir.). ;-)
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=117407#p117407]0.51 Win7 x64: keep folder structure doesn't work[/url]) wrote:
GeorgD wrote: XnViewMP v0.64: Tools > Batch convert > Add Folder > C:\tmp\sourceParent, Output Folder C:\tmp\target, "keep folder structure" activated (everything else disabled). Result:
C:\tmp\target
C:\tmp\target\Aus dem letzten Jahrhundert.jpg
C:\tmp\target\Funkenschlag Erweiterung Brasilien und Spanien+Portugal.JPG
C:\tmp\target\ruthe Geburtstag von Charles Darwin.jpg
=> the subfolders have NOT been created in the target
right, i've changed that, you can try last version of XnConvert...
GeorgD wrote: XnViewMP v0.64 ... => the subfolders have NOT been created in the target
Seems to be fixed in XnConvert 1.63, and hopefully will be in next XnViewMP release... :)
Tekila
Post by Tekila »
I tried the last version of Nconvert and it works fine when the output is a folder/directory. Thank you.
Nevertheless, it doesn't work when the output is FTP : in this case, the photos are transfered but the folder structure isn't conserved.
Is it possible to have the same correction for the ftp output ?
Thank you
Sebastien
