To all users of Xnview? hi there u no if u take a photograph and you think it is too close up? Well i just wondered there was a way using xnview to make them go further away. And if they are to far away to make them come closer. Thanks
_____________________
garden wholesales ~ online garden supplies ~ online garden supplies
Re: way using xnview to make them
If you mean to zoom in/out then you should use the "+" and "-" from the numerical pad on the right.merkutinaa wrote:To all users of Xnview? hi there u no if u take a photograph and you think it is too close up? Well i just wondered there was a way using xnview to make them go further away. And if they are to far away to make them come closer. Thanks
m. Th.
