0.64 preview window position not saved
lian
I had no problem with 0.51 version but in 0.64, with dualscreen, if I move the preview window on second screen and then close and reopen XnV MP, the preview window shows in first screen. More strange, saving the window position in "disposition" (layout ?), the problem is still there it I call the layout (and preview window is in first screen). If preview window is already in second screen, calling the layout works.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
m.Th.
Re: 0.64 preview window position not saved
I have the same setup with you but it works for me:lian wrote:I had no problem with 0.51 version but in 0.64, with dualscreen, if I move the preview window on second screen and then close and reopen XnV MP, the preview window shows in first screen. More strange, saving the window position in "disposition" (layout ?), the problem is still there it I call the layout (and preview window is in first screen). If preview window is already in second screen, calling the layout works.
Put the undocked Preview on the 2nd screen.
Save the layout.
Close the program
Open it again
It is as I left it last time.
Recall the layout: everything ok.
Btw, perhaps you're on an OS which has an 'odd' window manager (eg. some sort of Linux)?
m. Th.
lian
Windows Seven - as you can see in my signature. I wonder if the problem did not occur after I did an optimization of the database. Well, it's not very logic. Maybe I changed something in options ?
