Silent installation?
roblarose
Post by roblarose »
Xnview classic had a /silent switch -- MP seems to, too, but I get the Visual C++ installer as an interactive wizard.
Is there an option to skip this & get a full unattended installation?
--Rob
m.Th.
Re: Silent installation?
Post by m.Th. »
If you copy the XnView MP folder on another machine "as is" it just works.
Of course you will not have an icon in the Start menu but you can workaround this by a batch script to create it, by a shortcut on the desktop and/or pinning the program on the taskbar.
m. Th.
vcredist_x64.exe /q:a /c:"msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64.log"
