GDI Object Leak - xnview-1.80.1
Locked
Herrmann
Post by Herrmann »
When I switch between image and browser view via tabs the GDI Object counter in the taskmanager increases. After a while (~9000) it will cause display errors.
Re: GDI Object Leak - xnview-1.80.1
Herrmann wrote:When I switch between image and browser view via tabs the GDI Object counter in the taskmanager increases. After a while (~9000) it will cause display errors.
Where do you see GDI object counter???
Herrmann
Post by Herrmann »
I have a german windows 2000 version. Because I dont know whether my menu name translation is OK.
Taskmanager > View (3rd item) > Select (last item)
Check "GDI-Objects"
ckit
Post by ckit »
This is known as "GDI Handles" in Process Explorer (www.sysinternals.com)
Herrmann wrote:I have a german windows 2000 version. Because I dont know whether my menu name translation is OK.
Check "GDI-Objects"
I can't find it :-( Could you make a screenshot please?
marsh
Post by marsh »
I can confirm high count of GDI Objects (whatever that is) when:
1. Folder tabs enabled.
2. [x] 'One View Opened'
3. Browser>Fullscreen>Viewer mode.
4. Hold down <enter> key over tiny image.
5. Count does not rise when folder tabs are unchecked on menu.
(Win2K SP4; Rollup Update 1; Windows task manager screenshot)
(select columns screenshot)
ckit
Post by ckit »
I can confirm there is a resource leak in GDI Objects\Handles.
Everyone please switch to using "Process Explorer 9.12" it's far more professional.
It can be downloaded here - www.sysinternals.com
ckit wrote:I can confirm there is a resource leak in GDI Objects\Handles.
Ok, now me too :-(
marsh
Post by marsh »
GDI leak -new: 'Show Information' in 'browser fullscreen' mode.
(This can cause counter to rise to many thousands if quick slideshow is used. I'm not using tabs.).
'Show Information' does not leak in viewer fullscreen.
At 9999, I got display errors requiring restart.
F12 has tiny leak. 'About' has tiny leak. But these won't accumulate quickly like the 2 others will.
marsh wrote:GDI leak -new: 'Show Information' in 'browser fullscreen' mode.
Ok, confirmed
marsh
Post by marsh »
Big leaks confirmed fixed. v.1.80.2RC
Locked
