issue bug for text portrait orientation
drugo
Post by drugo »
Hi
there is an issue or maybe a bug about text a photo with portrait orientation
using the text percentage , it works perfectly with landscape but it doesn't fit in portrait orientation
in the portrait orientation the text is out of the images
the problem begins when i there are photos with landscape and portrait orientation
thanks
Re: issue bug for text portrait orientation
could you post the result of landscape & portrait, please?
drugo
Post by drugo »
xnview wrote:could you post the result of landscape & portrait, please?
yes
here
images , the only effect on is Text
resize doesn't fix!
ok, currently i use % on bitmap height, perhaps i need to use on min(width, height) but even the text will not fit (with your text size)
text size is the height of the text.
drugo
Post by drugo »
xnview wrote:ok, currently i use % on bitmap height, perhaps i need to use on min(width, height) but even the text will not fit (with your text size)
Hi Pierre
will be fixed?
thanks
but even if i use min(width, height), the text will not be fully visible :(
drugo
Post by drugo »
xnview wrote:but even if i use min(width, height), the text will not be fully visible :(
maybe the program could detect the orientation and calculate the right text size
As i said, the % is for text height, not text width. If i understand you, you want % for text width?
