Minimum viewer window size (smaller wanted)
nim
Post by nim »
Could you add this setting to xnview.ini?
after having hidden everything including menubar there isn't much point in limiting how small a window can be on start up and if you want to open many windows viewing images that are quite small and clutter your free desktop space with them for reference when working it'd be awesome if the window size would always fit the image.
if the ViewHeight and ViewWidth items are supposed to control this I haven't gotten them to work.
Cheers,
Erik
EDIT: I realise this has been discussed in this thread from 2007 http://newsgroup.xnview.com/viewtopic.php?f=36&t=14079 . It didn't turn up on searching but reviewing my subscriptions I realised I had already requested this but 2007 was some time ago :-)
