The most used format
lostcpu
Post by lostcpu »
"The most used format" in saving windows like xnview is needed in xnview MP
now the efficiency of format selection in MP "save as" window is very low.
Re: The most used format
you means the choice of format in save as dialog??
slow??
lostcpu
Post by lostcpu »
yes, I mean the choice of format in save as dialog.
in old xnview, user can select "bmp,jpg,png,gif" or whatever format they like as the most used formats, and when selecting a format in save as dialog they are on the top of format list.
in xnview mp, "bmp,jpg,png,gif" just mixed up with other formats like normal extentions and waste a little time to click the one I want to use.
xnview wrote:you means the choice of format in save as dialog??
slow??
See Issue 313 for current status and details.
lostcpu
Post by lostcpu »
thank you so much, waiting for 0.66
xnview wrote:See Issue 313 for current status and details.
