"Convert to colors" problem (png)
zed
Post by zed »
Try the attached file (not white rect - it is white tank with transparency :) to "Convert to colors" (png).
Result - image dublicated in one canvas.
Re: "Convert to colors" problem (png)
sorry but what's the problem?
Before:
Image > Convert to Colours -- Colours 256 -- Dithering None
Duplicated??
Edit:
Are you using XnView Classic or XnViewMP?
The XnViewMP function Image > Change color depth... converts the image transparency to white rather than black, resulting in a white rectangle as you posted above, as the source image is pure white:
