Bug with folders in CLI (Command Line Interface)
m.Th.
Post by m.Th. »
In CLI XnView MP does not support folders with spaces.
Steps:
1. Make a folder named "Folder 1" (with spaces) in C:
2. Go to command line and write
xnview "C:\Folder 1\"
Expected:
XnView should open the Folder 1 in browser.
Actual:
A "File Not Found!" message appears.
Notes:
The code works for folders without spaces. IOW if it would be Folder1 and the command line would be xnview c:\folder1 then it would work.
Pierre, please support embedding the folder paths in quotes.
For the files it works ok.
m. Th.
Re: Bug with folders in CLI (Command Line Interface)
See Issue 318 for current status and details.
Works fine for me in v0.84. With "c.\programme\xnviewmp.exe" "c:\folder 1" or "c.\programme\xnviewmp.exe" "c:\folder 1\" XnView starts and opens folder 1.
:arrow: Closed. Please post here in case the problem should still occur.
