File associations ... why?
Asterisco
Post by Asterisco »
Yes. The question is:
Why XnView is the only software I have problems with to set file associations?
I'm using XP for 10 years and I have never found a software so difficult to manage file associations.
There are some great features in this software but this is not acceptable.
Sorry, i have to come back to to my old software.
Thanks
(Could be a great feature if you can fix this subject...)
Re: File associations ... why?
what problem?
Asterisco
Post by Asterisco »
Hello Pierre. The problem is I can not set file associations for XnView MP without hassles. I'm using XP as administrator.
I install software every day and this is the only software that makes user account restriction dialog appear. I think something is wrong with the setup routine, and you would have to fix this, because is not a good behavior.
Thanks again.
(very good software anyway)
I don't understand, i've tried on Xp and have no dialog about user restriction...
