For some tests I needed a *.webp image file.
In XnViewMP 0.64 I loaded a *.jpg file and tried to save this image as *.webp file.
In case of the quality for saving a *.webp file is > 97 the saved file is corrupted with afile size of less than 5 Kb.
Best regards
Herb
Corrupted *.webp file
Re: Corrupted *.webp file
I can't reproduce, could you post the picture file?
herb
Hello Pierre,
you are right, the error does not happen with all files.
But it happens with a file I have downloaded from internet in order to perform some Exiftool tests.
I have sent the file via mail.
Best regards
Herb
Best regards
Herb
