Rotated Image Thumbnail Display?
evetsf8
Post by evetsf8 »
New XnViewMP user here...
I have some images that were rotated 90 degrees by another application.
When I use XnVewMP, the Preview panel shows the image in its correct rotation, but the thumbnails are shown in the original un-rotated orientation.
Is there a setting somewhere that would show thumbnails correctly rotated?
Thanks,
Steve
m.Th.
Re: Rotated Image Thumbnail Display?
Post by m.Th. »
evetsf8 wrote:New XnViewMP user here...
Thanks,
Steve
It depends on what you have. JPEGs? ...anyway, perhaps more details would be better.
Till then, try: in Settings | General -> Rotate images according to EXIF orientation tag
After this, select all thumbs and go to View | Rebuild Thumbnails
m. Th.
evetsf8
Post by evetsf8 »
Thanks for this information. I had found the option in Settings, but not the rebuilding of thumbnails. I'll try that over the weekend on the machine where it's installed.
Steve
