browsing window remains empty
hifly156
Post by hifly156 »
I'm really keen on this program and use it for many years.
The issue I'm having right now is that the browsing mode stopped working.
The window remains blank, even when there are files in the directory.
Have a look here for a screenshot:
http://sintjansberg.be/downloads/XnView ... 150718.png
I did optimize the database, did not work. Then cleared it.
What else can I do to get it working?
Running OS 10.9.2 XnView MP 0.64
m.Th.
Re: browsing window remains empty
Post by m.Th. »
hifly156 wrote:Hello,
1. Perhaps you have a filter active?
Go to View | Filter By... and choose All.
2. Perhaps you have problems with the Custom Filter?
Go to Tools | Settings | File List | Custom Filter
and check all the checkboxes there. Alternatively can you post a screenshot of this tab from the Settings window?
3. As a last resort, go to folder where your xnview.ini is and, with XnView MP closed, rename the file to xnview.old to reset everything.
Please report back.
m. Th.
hifly156
Post by hifly156 »
Oh thank you, it was a filter :?
