Full support for zip and rar files
The behavior of zip and rar files as no different than folders is the one and only reason I am still using ACDSee. In ACDSee, a zip or rar is 100% identical to a regular folder for the purpose of browsing. Editing the files inside works differently (mostly, you can't, although in the newer versions they have gotten some features to work), but I am not concerned with this. What I need to be able to do is browse around these files with all features enabled, such as being able to go to the next and previous file, use a slideshow, and other strictly viewing oriented functions. Many things are distributed as large numbers of image files inside a zip or rar file so as to distribute a single file instead of a large number of separate files, and not being able to view these types of pseudo-folders is an extremely large problem, since about 80% of what I use a program like XnView to look at is in this format.
The way the archive add-on for XnView currently works is in no way shape or form a suitable or useful replacement for the way ACDSee handles these files. The lack of ability to use standard methods for moving around inside these files is crippling. Only when they are treated exactly the same way as folders, natively or via an add-on, will XnView be usable as my full time image software.
Re: Full support for zip and rar files
Still need this. Also internal support for gfy would be nice.
Still can't use XN View because the one piece of functionality I absolutely cannot go without is not in the program.
Still waiting. Cannot use this as a replacement for ACDSee without this feature.
Continuing to wait.
I continue to be unable to use XnView as my main software tool due to the lack of this critical feature. There is a much more active discussion of this under the MP suggestions.
i wonder why should i store images in a zip? most modern image formats are compressed already, so i fail to see any advantage of doing so.
- Moderator & Librarian
From the MP forum:heimaki wrote:i wonder why should i store images in a zip? most modern image formats are compressed already, so i fail to see any advantage of doing so.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=125045#p125045]Full support for zip and rar files[/url]) wrote:Dropbox, Gallery2/Gallery3, jAlbum, Photobucket, Picasa, SmugMug, Snapfish, TYPO3, ASOASFobelisk wrote:Nobody stores jpgs in a zip/rar because it ends up 99-101% of original size.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=125059#p125059]Full support for zip and rar files[/url]) wrote:You can tell XnView Classic to treat files with certain extensions as text by editing xnview.ini:Marsu42 wrote:Btw this would xnview also a very suitable viewer for .cbr and .cbz ebooks that are simply an archive of scanned images.
I'd like to have the same functionality for archive formats:Code: Select all
TxtExt=txt c c++ cc h cpp pas js css php ini
7zExt=cb7 CabExt= RarExt=cbr ZipExt=cbz curxptheme docx jar oxps potx pptx svgz wmz xlsx xpi xps TarExt=cbt
sure, i can download an "album" from the net, but the first thing i'd do is unpacking that archive once the download is finished.
i still can't see any advantage of a zipped gallery on my local drives, only disadvantages.
Let's leave that to the individual user (and developer). I'd appreciate full support for archives independent of their filename extension.heimaki wrote:sure, i can download an "album" from the net, but the first thing i'd do is unpacking that archive once the download is finished.
i'm not the one asking.XnTriq wrote: Let's leave that to the individual user (and developer).
I was referring to the (individual) developer(s) who dare to create file formats based on common archive formats.heimaki wrote:i'm not the one asking.the developer doesn't seem to be keen on implementing this after all.
ahhhh got it.
yes, those really are brave devs.
Among others, I have hundreds of comics in zip or rar format as originally distributed by the businesses selling them that say it's a fairly common way to store groups of images.
