Hello.
I'm using counter in viewer status bar, which tells current image number and total number of images in status bar. It shows different behavior in different situations:
1) if I run image viewing directly from folder (i.e. using FAR manager - navigate to folder - run image file) - then delete some image from viewer - total number of images doesn't decrement, current image number is incremented (i.e. before deletion: 3/600, after deletion: 4/600)
2) if I run image viewing from XnView -> navigate to folder -> view image - then deletion of some image gets total number decremented and current image number stays the same (i.e. before deletion: 3/600, after deletion: 3/599)
Imho, #2 looks right to me. Yet, both situations should show same behavior.
Also, looks like #1 affects speed of viewer when scrolling between images (trying to open already deleted images in list?)
Regards.
Images position/counter in status bar bug
