scanner :
I miss the acquire function , i uninstalled reinstalled the old version of xnview and it works ,
i am keeping the oldversion for the timebeing.
thks
scanner doest not work with MP
Re: scanner doest not work with MP
do you have xnviewmp x64?
murphy_chang
I have the same problem, I use win8.1 x64 . when I install mp 0.64 x86, it work fine but not in X64. Please check.
If you use XnViewMP x64, you need twain driver x64, often there is only x32 version
