Change Timestamp doesn't create Exif data
toralf
Post by toralf »
XnViewMP 0.64
"Tools/Change Timestamp" doesn't create Exif times when they do not exits, but the checkbox for "Create EXIF metadata if needed" is checked. And all three EXIF Dates are checked too.
ciao
toralf
XnViewMP v0.64 64bit on Win8.1
CameronD
Re: Change Timestamp doesn't create Exif data
Post by CameronD »
discussed here.
Pierre has marked it as resolved, to appear in v0.66.
