Using 1.80.1, when I do an "Acquire into..." the program overwrites existing files, unless I manually increase the starting number. Is there a way to automatically continue where the previous batch ended, or better yet to automatically fill in empty "slots"?
Is it also possible not to have the auto-numbers inserted at the end, for instance with ACDSee you use "#" as placeholders and can thus define a filename as "abc-###-def.jpg".
How about being able to also insert a timestamp into the filename? And if it can be user-defined... Great!
"Acquire into..." questions...
RISadler
Re: "Acquire into..." questions...
Ok, i'll add user defined filename...Jagdpanzer wrote:Using 1.80.1, when I do an "Acquire into..." the program overwrites existing files, unless I manually increase the starting number. Is there a way to automatically continue where the previous batch ended, or better yet to automatically fill in empty "slots"?
RISadler
