Minor: Unnecessary square when RMB is pressed
Dreamer
There is unnecessary square (around the cursor) when RMB is pressed to show context menu (only when RMB is set to make selection).
Dreamer
Re: Minor: Unnecessary square when RMB is pressed
The "square" comes from the handles which can be used for resizing a selection. If you make a very small selection you can see.Dreamer wrote:There is unnecessary square (around the cursor) when RMB is pressed to show context menu (only when RMB is set to make selection).
Dreamer
I know, but it's a bit annoying, that square should appear after cursor is moved, not immediately when RMB is pressed.helmut wrote:The "square" comes from the handles which can be used for resizing a selection. If you make a very small selection you can see.Dreamer wrote:There is unnecessary square (around the cursor) when RMB is pressed to show context menu (only when RMB is set to make selection).
I think that this is a very minor issue which does not disturb at all (you have marked it as "minor" in the subject, already). Rather than spending time with very little issues we should focus on the real problems and enhancements. I think there's still many, many of them...Dreamer wrote:I know, but it's a bit annoying, that square should appear after cursor is moved, not immediately when RMB is pressed.
Dreamer
