There is a bug with the Tools | Rename - it is not looking in subfolders.
Have:
c:\f1
c:\f1\f12
c:\f1\f13
Go to c:\f1, select f12 and f13 and choose Tools | Rename - it should allow to rename the files inside of the subfolders.
The things become more dangerous when the user selects together some photos with the folders f12 and f13. He thinks that the files from the subfolders will be renamed (like Batch Convert does) - however the program does not rename them.
Rename - Not looking in subfolders
m.Th.
m. Th.
