Indication of saturated areas in a picture
B.Douille
Post by B.Douille »
Some cameras does this: Showing saturated areas in the image so you know that you should select a different setup and take another picture.
The pixels where the numeric values reaches 253-255 are blinking in shades of greys, indicating near-saturation. Why not having this feature embedded in XnView MP?
That's a common issue when adjusting color/contrast / Brightness / Gamma... to reach the limit of the dynamic range in one or more color plan, destroying the actual colours. Shift-Ctrl-I allows to chase in zones that we suspect are close to the limits. The histogram helps but is not as obvious as the blinking pixels. This could be activated / deactivated as a general option (excluding fullscreen) or specifically in dialogs that allows these changes.
The same could be done for dark areas (any colour very close to 0).
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Indication of saturated areas in a picture
B.Douille
Post by B.Douille »
I didn't found these requests on overexposed / underexposed areas. Thank you.
In the mean time, can we have the Histogram feature enhanced a bit to allow Ctrl-Z?
In the current version of XnViewMP, it's a static graph linked to the existing file content so when doing adjustments the graph doesn't change.
To evaluate the result we need to save the file and close/reopen (or navigate to next picture / go back.
This kills any possibility to do fall-back via Ctrl-Z :(
Thank you
m.Th.
Post by m.Th. »
B.Douille wrote:I didn't found these requests on overexposed / underexposed areas. Thank you.
Thank you
This is very important and will get overlooked here. You need to start a new thread with this. But the problem isn't Ctrl-Z. It that the Histogram is useless/wrong because is desynced from the actual picture at first edit. When the screen image is updated the histogram (if visible) needs to be also updated.
m. Th.
