I played a bit with XnView MP, configured interface, decided that I like it and associated files with it. Unfortunately files open in dysfunctional full screen mode, where basic shortcuts are not working.
How can configure program so opening file in XnView MP will result the same interface as opening XnView MP and selecting image?
How can I configure default interface after opening file?
bulwersator
m.Th.
Re: How can I configure default interface after opening file
bulwersator wrote:I played a bit with XnView MP, configured interface, decided that I like it and associated files with it. Unfortunately files open in dysfunctional full screen mode, where basic shortcuts are not working.
The shortcuts from Full Screen mode are the same shortcuts from View mode. If you go to the Tools | Settings and find the Shortcuts tab you'll see that the "list" of the shortcuts is, in fact, a tree with two very big branches: Browse mode and View mode.
m. Th.
bulwersator
So to rephrase my question: is it possible to associate file extensions with opening in browse mode?
no only in view modebulwersator wrote:So to rephrase my question: is it possible to associate file extensions with opening in browse mode?
