Default save type?
VengeArturia
Default save type?
When opening say, a .png or a .bmp file, doing Save As always seems to default to the same file type as the image's current type. Is there a way to make this default to .png or .jpg?
Re: Default save type?
no, so you would like an option 'keep format for saving'?
oops66
... Yes (for me), it's a good ideaxnview wrote:no, so you would like an option 'keep format for saving'?
Wouldn't retaining the last file type saved be a simpler solution than adding another option?VengeArturia wrote:Save As always seems to default to ... the image's current [file] type...
VengeArturia
I agree. Old XnView would remember the last file format you saved at and used that as a default when saving, which I personally enjoyed.oops66 wrote:... Yes (for me), it's a good ideaxnview wrote:no, so you would like an option 'keep format for saving'?
