XnView 2 Deluxe + Plugins PSElts
pierrederonsard
Post by pierrederonsard »
In XnView 2 Deluxe, the PSE plugins cannot be used : when user selects the right directories (like is XnView 1.80), the plugins are not avalaible in the "Module manager" and cannot be selected...
PS : is there a separate forum for Deluxe ?
Re: XnView 2 Deluxe + Plugins PSElts
pierrederonsard wrote:In XnView 2 Deluxe, the PSE plugins cannot be used : when user selects the right directories (like is XnView 1.80), the plugins are not avalaible in the "Module manager" and cannot be selected...
I have not PSelts...
No, all bugs for Deluxe are generally sent to Xzeos...
pierrederonsard
If you do not have Photoshop Elements, there is a link to a sample Nikon filter for PSE I use (install program), and a screenshot here :
http://charond1.perso.cegetel.net/
This problem is specific to Deluxe 2, 1.80 is ok.
I will send the topics about Deluxe 2 Xzeos in the future, maybe it is better for you and the other XnView free users.
Thanks Pierre
