In the IPTC editor (Ctrl+I), you can add keywords mostly using the keyword.
However to move to the next image either you can press TAB many times or use the mouse.
Suggest adding a shortcut for moving to the next and previous images. This will allow quick keyword entry.
For example, Adobe Lightroom uses Ctrl+Right Arrow and Ctrl+Left Arrow. Please do not implement PgUp/PgDown keys, as most laptops these days do not have these keys dedicated anymore (unfortunately!). Another suggestion is Ctrl+> or Ctrl+< key.
Thanks!
Keyboard shortcut for next/previous image in IPTC Editor
aidanw
Re: Keyboard shortcut for next/previous image in IPTC Editor
See Issue 379 for current status and details.
GJJ
just to approve this suggestion using the "Ctl"+">" key combination.
Is it already implemented ? at the moment, I am using the XnViewMP 0.71 x64 on Windows OS
Georges
Georges
it's implementedGJJ wrote:just to approve this suggestion using the "Ctl"+">" key combination.
Georges
