Customizing keyboard shortcuts and thumbnails
prr
Post by prr »
First of all, so far so good--thanks for developing this software. It starts up nice and fast, which is more than I can say for other graphics viewers.
Also, thanks for having a text-only captcha, instead of that complicated crap that most forums insist on.
OK now, on to my questions.
(1) Is it possible to customize keyboard shortcuts? I'm used to hitting F for fullscreen, instead of F11. this is obviously not a biggie for me, but I'd still prefer to do this if I could.
(2) I see some small tags on my thumbnails, such as (if I am seeing the letters correctly) EXIF and ICC. Is there a way not to see these tags?
Thanks.
prr
Re: Customizing keyboard shortcuts and thumbnails
Post by prr »
Found out how to get rid of those tags. Go to Tools/Options, then the Thumbnail selection on the left. Select the Icon Info tab on the right pane, and then deselect all choices in the File info section. OK out and you're done.
