can't run program
fominator
can't run program
Post by fominator »
Can anyone tell me how to use this program, if at startup I got this
fix this
Re: can't run program
Do you had previous version?
fominator
Post by fominator »
it was the same in previous, I thought you'll fix it
if you drag&drop a picture file on the icon of the program?
fominator
Post by fominator »
can't you see that problem is the browser! you can see it on screenshot
in other ways everything's alright
fominator
Post by fominator »
to start program I delete .ini file and change browser view, but the problem exist
i don't understand, when do you have this problem?
fominator
Post by fominator »
it's hard to write in English
1. first start - fine
2. go to full screen window OR stretch window wherever you want
3. close program
4. next start gives this problem
i have to delete ini file and next time stretch window and go to full screen window (somehow it helps) OR change browser to list view if I don't want full screen
it's very uncomfortable
do you understand?
fominator
Post by fominator »
or I can check this option
icons don't match the browser borders at startup or smth like that
In the startup folder, do you have only jpeg files? movies?
fominator
Post by fominator »
it's everytime on icons view, everywhere! even if there is only one folder
again - look at borders!! on list view everything's ok
try to disabled 'show as thumbnail' for folder in option>file list>Custom filter
fominator
Post by fominator »
I said it many times! do you read what I write? on list view (without thumbnails) everything's fine! but problem exists! I just want you to know about problem that can confuse everyone on windows 8.1 64 bit
fominator wrote:I said it many times! do you read what I write? on list view (without thumbnails) everything's fine! but problem exists! I just want you to know about problem that can confuse everyone on windows 8.1 64 bit
I have not this problem at all on win8.1, do you have changed this setting?
fominator
Post by fominator »
not at all!!! I described exactly how it happens - step by step
I don't know why you haven't this problem - as you see on the screenshot the problem exists
I didn't do anything special - it just a bug and nothing more
