can't run program
oops66
Re: can't run program
Post by oops66 »
... Maybe you can try to download it again ... ?
@Pierre, ... Maybe a MD5 checksum is needed for each XnView(MP) version to be sure than the downloaded file is not corrupted (to avoid this kind of problem)
XnViewMP Linux X64 - Debian - X64
fominator wrote:not at all!!! I described exactly how it happens - step by step
I don't know why you haven't this problem - as you see on the screenshot the problem exists
I didn't do anything special - it just a bug and nothing more
could you desactive this setting to check if the bug occurs
fominator
Post by fominator »
which setting? I don't understand
fominator
Post by fominator »
oops66 wrote:Hello,
I've tried, didn't help
Could you change the language of your copy of XnViewMP to English temporarily and post an image of the above error message you are obtaining: (In English: Tools > Settings... -- General -- Language).
Note you can use 'Alt + PrintScreen' to capture just the error message window, and screenshots are best saved as PNGs...
disable 'show as thumbnail' for folder in option>file list>Custom filter
fominator
Post by fominator »
read the discussion above PLEASE
fominator wrote:to start program I delete .ini file and change browser view, but the problem exists
fominator wrote: i have to delete ini file and next time stretch window and go to full screen window (somehow it helps) OR change browser to list view if I don't want full screen
fominator wrote:I said it many times! do you read what I write? on list view (without thumbnails) everything's fine! but problem exists! I just want you to know about problem that can confuse everyone on windows 8.1 64 bit
so I told you about it many times - why don't you listen to me? if disable 'show as thumbnail' everything's fine, but the bug exists, IN GENERAL I mean
I don't talk about 'show as thumbnails', but the option in 'file list'
Do you have video files on subfolder?
fominator
Post by fominator »
no, I don't have it
I told you that too))
by the way - in xnview I don't have this issue
which file format do you have in cameraroll folder?
neod
Post by neod »
I have the same problem. It seems that the issue occurs after I disable the "Sets of categories" Data pane. Disabling 'show as thumbnail' for folders does not help. The only way that works for me to open the program again without crashing it is to remove the PathBrowser and customPath values in the xnview.ini file.
fominator
Post by fominator »
xnview wrote:In the startup folder, do you have only jpeg files? movies?
fominator wrote:it's everytime, everywhere! even if there is only one folder
camera roll is empty
if you delete the xnview.ini, it starts the first time, right?
Do you have tried to re-download it?
When you have the crash could you send the report?
neod wrote:I have the same problem. It seems that the issue occurs after I disable the "Sets of categories" Data pane. Disabling 'show as thumbnail' for folders does not help. The only way that works for me to open the program again without crashing it is to remove the PathBrowser and customPath values in the xnview.ini file.
Do you have tried with a clean xnview.ini/xnview.db?
fominator
Post by fominator »
yes
yes
report? with pleasure!! but how?
